AWS S3 Content Pack
Amazon S3 is an object storage service. This content pack processes two S3 log families: AWS CloudTrail S3 data events (event_source=s3.amazonaws.com) and S3 server access logs.
Messages are normalized into the Graylog Information Model, or GIM (file.create, file.delete, file.access, audit.policy, audit.default) with Security Core coverage. A lightweight single-event detection flags CloudTrail cross-bucket CopyObject operations as potential data exfiltration (301001 host_dlp_detection).
Supported Version(s)
AWS CloudTrail S3 data events (CloudTrail record version 1.08 and 1.09)
AWS S3 server access log format (current version as of April 2026)
Graylog 7.1+ with a valid Enterprise license
Stream Configuration
- Illuminate:AWS S3 Messages
Index Set Configuration
- AWS S3 Logs
Log Collection and Delivery
This pack parses logs from the following sources:
AWS CloudTrail S3 data events forwarded via the AWS CloudTrail input, the AWS Kinesis/CloudWatch input, or an S3-to-Graylog forwarder.
AWS S3 server access logs parsed by a forwarder (Lambda or similar) that reads the log bucket and forwards GELF/JSON messages.
CloudTrail Delivery
Enable data events for the S3 buckets of interest in a CloudTrail trail. See the AWS documentation on logging data events for details.
Send the trail to an Amazon SNS topic with an SQS subscription.
In Graylog, create an AWS CloudTrail input that reads from that SQS queue.
If you decode the trail with your own forwarder instead, note the following:
You must send one CloudTrail record per message.
Map the raw JSON object to the
messagefield.
S3 Server Access Log Delivery
Enable server access logging on each bucket you want to monitor, routing the logs to a dedicated logging bucket.
Create an AWS Lambda function that triggers on S3
ObjectCreatedevents on the logging bucket. -
Configure the function to parse each log file using the space-delimited S3 access log format.
Forward each parsed record as a separate message to a Graylog GELF input.
Log Format Examples
These are example logs for the two supported AWS S3 log families.
CloudTrail S3 Data Event
# AWS CloudTrail S3 Data Event (decoded record, one per message)
"eventVersion": "1.09",
"userIdentity": {
"type": "IAMUser",
"principalId": "AIDAEXAMPLEID1234",
"arn": "arn:aws:iam::111122223333:user/alice",
"accountId": "111122223333",
"userName": "alice"
"eventTime": "2026-04-15T10:15:22Z",
"eventSource": "s3.amazonaws.com",
"eventName": "PutObject",
"awsRegion": "us-east-1",
"sourceIPAddress": "203.0.113.45",
"userAgent": "aws-cli/2.13.0 Python/3.11",
"requestParameters": {
"bucketName": "example-app-uploads",
"key": "inbox/2026/04/15/report.csv"
"responseElements": null,
"eventID": "3fcd7213-a8dd-c88a-d151-58665299f60b",
"readOnly": false,
"resources": [
"type": "AWS::S3::Object",
"ARN": "arn:aws:s3:::example-app-uploads/inbox/2026/04/15/report.csv"
"type": "AWS::S3::Bucket",
"ARN": "arn:aws:s3:::example-app-uploads"
"eventType": "AwsApiCall",
"managementEvent": false,
"recipientAccountId": "111122223333",
"eventCategory": "Data"
S3 Server Access Log (raw AWS format)
# AWS S3 Server Access Log (space-delimited, one line per request)
# Field order: bucket_owner bucket [time] remote_ip requester request_id operation key "request_uri" http_status error_code bytes_sent object_size total_time turn_around_time "referer" "user_agent" version_id host_id signature_version cipher_suite authentication_type host_header tls_version access_point_arn acl_required
a1b2c3d4e5f67890canonicaluserid1a2b3c4d5e6f7890a1b2c3d4e5f67890 example-app-uploads [15/Apr/2026:10:15:22 +0000] 203.0.113.10 arn:aws:iam::111122223333:user/alice A1B2C3D4E5F60718 REST.PUT.OBJECT inbox/2026/04/15/upload.png "PUT /inbox/2026/04/15/upload.png HTTP/1.1" 200 - 0 524288 145 12 "-" "aws-cli/2.13.0" - abcdef0123456789 SigV4 ECDHE-RSA-AES128-GCM-SHA256 AuthHeader example-app-uploads.s3.us-east-1.amazonaws.com TLSv1.3 - -
a1b2c3d4e5f67890canonicaluserid1a2b3c4d5e6f7890a1b2c3d4e5f67890 example-static-assets [15/Apr/2026:10:16:02 +0000] 198.51.100.12 - B2C3D4E5F6071819 REST.GET.OBJECT images/logo.png "GET /images/logo.png HTTP/1.1" 200 - 18211 18211 8 2 "-" "Mozilla/5.0" - hostid0123456789 - - - example-static-assets.s3.us-east-1.amazonaws.com TLSv1.3 - -
a1b2c3d4e5f67890canonicaluserid1a2b3c4d5e6f7890a1b2c3d4e5f67890 example-data-lake [15/Apr/2026:10:20:45 +0000] 203.0.113.66 arn:aws:iam::444455556666:user/external-user C3D4E5F607181920 REST.GET.OBJECT sensitive/finance.xlsx "GET /sensitive/finance.xlsx HTTP/1.1" 403 AccessDenied 243 2048000 9 - "-" "curl/8.0.1" - hostid9876543210 SigV4 - - example-data-lake.s3.us-east-1.amazonaws.com TLSv1.3 - -
S3 Server Access Log (forwarded shape the pack expects)
# S3 Server Access Log -- forwarded shape (what the pack expects as input)
# The forwarder reads the raw space-delimited record and emits one
# JSON/GELF message per line with the fields below. Keep the AWS
# field names on the way in; the pack's 10-aws_s3_access_log_processing
# rule performs the rename to Graylog schema fields.
# Minimal identification triple: bucket_owner + bucket + operation.
# No `source` label required; source=s3-access-log-forwarder is also accepted.
"short_message": "203.0.113.10 REST.PUT.OBJECT example-app-uploads/inbox/2026/04/15/upload.png",
"bucket_owner": "a1b2c3d4e5f67890canonicaluserid1a2b3c4d5e6f7890a1b2c3d4e5f67890",
"bucket": "example-app-uploads",
"timestamp": "2026-04-15T10:15:22Z",
"remote_ip": "203.0.113.10",
"requester": "arn:aws:iam::111122223333:user/alice",
"request_id": "A1B2C3D4E5F60718",
"operation": "REST.PUT.OBJECT",
"key": "inbox/2026/04/15/upload.png",
"request_uri": "PUT /inbox/2026/04/15/upload.png HTTP/1.1",
"http_status": 200,
"error_code": "-",
"bytes_sent": 0,
"object_size": 524288,
"total_time": 145,
"turn_around_time": 12,
"referer": "-",
"user_agent": "aws-cli/2.13.0",
"version_id": "-",
"host_id": "abcdef0123456789",
"signature_version": "SigV4",
"cipher_suite": "ECDHE-RSA-AES128-GCM-SHA256",
"authentication_type": "AuthHeader",
"host_header": "example-app-uploads.s3.us-east-1.amazonaws.com",
"tls_version": "TLSv1.3",
"access_point_arn": "-",
"acl_required": "-"
What is Provided
Rules to parse, normalize, and enrich AWS S3 CloudTrail data events and S3 server access logs.
GIM categorization for S3 object create, access, delete, audit policy change, audit default, and cross-bucket data exfiltration detection.
Security Core coverage for file and audit categories.
The content pack supports the following log types.
AWS CloudTrail S3 data events (PutObject, GetObject, HeadObject, CopyObject, DeleteObject, DeleteObjects, ListObjects, REST.PUT.BUCKETPOLICY, and similar)
S3 server access log operations (REST.PUT.OBJECT, REST.GET.OBJECT, REST.DELETE.OBJECT, REST.POST.MULTI_OBJECT_DELETE, REST.GET.BUCKET, REST.PUT.BUCKETPOLICY, and similar)
GIM Categorization
| Event | gim_event_type_code | GIM Category | GIM Subcategory | GIM Event Type |
| PutObject / REST.PUT.OBJECT | 200000 | file | file.create | file created |
| CopyObject | 200000 | file | file.create | file created |
| GetObject / REST.GET.OBJECT | 201500 | file | file.access | file accessed |
| HeadObject / REST.HEAD.OBJECT | 201500 | file | file.access | file accessed |
| DeleteObject / REST.DELETE.OBJECT | 200100 | file | file.delete | file deleted |
| DeleteObjects / REST.POST.MULTI_OBJECT_DELETE / BATCH.DELETE.OBJECT | 200100 | file | file.delete | file deleted |
| ListObjects / ListBuckets / HeadBucket / GetBucketPolicy / GetBucketAcl / GetBucketLocation / REST.GET.BUCKET / REST.HEAD.BUCKET / REST.GET.* | 229999 | audit | audit.default | audit event |
| REST.PUT.BUCKETPOLICY | 220500 | audit | audit.policy | audit policy changed |
| CopyObject (detection: cross-bucket exfil) | 301001 | detection | detection.host_detection | host_dlp_detection |
General Parsing for AWS S3
| event_source_product | aws_s3 | string | Identifies the log source product as AWS S3 |
| event_created | 2026-04-15T10:15:22.000Z | date | Event time parsed from the CloudTrail eventTime or the S3 access log request time, so search and dashboards use event time rather than ingest time |
| event_log_name | AWS S3 CloudTrail Data Event | string | Static log-source name per transport: AWS S3 CloudTrail Data Event or AWS S3 Server Access Log |
| vendor_aws_event_source_api | s3.amazonaws.com | string | AWS service endpoint that emitted the event (vendor passthrough; no canonical SDM field exists) |
| vendor_aws_region | us-east-1 | string | AWS region the call was made in (CloudTrail awsRegion; vendor passthrough, no canonical SDM field exists) |
| vendor_event_module | PutObject | string | Raw operation name from CloudTrail event_name or S3 access log operation; keyed by the GIM lookup |
| vendor_event_action | PutObject | string | Same as vendor_event_module; keyed by the event_action lookup |
| vendor_event_description | PutObject | string | Human-readable summary; mirrors vendor_event_action. Satisfies audit.* GIM enforcement. |
| event_action | created | string | Normalized action (created, read, deleted, modified) derived via the aws_s3_event_action_lookup |
| event_outcome | success | string | success by default; failure when CloudTrail reports error_code or the access log http_response_code >= 400 |
| source_user_name | alice | string | CloudTrail user identity userName (for CloudTrail events) |
| source_user_id | AIDAEXAMPLEID1234 | string | CloudTrail user identity principalId, or S3 access log requester (ARN/canonical ID) |
| source_user_domain | 111122223333 | string | AWS account ID of the caller (from CloudTrail user_identity_accountId) |
| vendor_user_arn | arn:aws:iam::111122223333:user/alice | string | Caller ARN (from CloudTrail user_identity_arn). AWS-specific; no canonical User schema field exists for ARNs. |
| vendor_user_type | IAMUser | string | CloudTrail user_identity_type (IAMUser, AssumedRole, Root, AWSService, etc.) |
| user_name | alice | string | Mirror of source_user_name so file.* GIM enforcement (which requires user_name) is satisfied |
| user_id | AIDAEXAMPLEID1234 | string | Mirror of source_user_id so downstream user-based queries resolve either field |
| source_ip | 203.0.113.45 | ip | Caller IP address (from CloudTrail source_ip_address or S3 access log remote_ip) |
| vendor_bucket_name | example-app-uploads | string | S3 bucket name involved in the operation |
| file_name | inbox/2026/04/15/report.csv | string | S3 object key |
| file_path | s3://example-app-uploads/inbox/2026/04/15/report.csv | string | s3:// URI built from bucket + object key |
| host_hostname | example-app-uploads.s3.amazonaws.com | string | Synthesized from the bucket name so the core reference rule derives host_reference for file.* enforcement |
| http_response_code | 200 | integer | HTTP status from the S3 access log (not present on CloudTrail messages) |
| http_response_bytes | 0 | long | Access log: number of HTTP response bytes sent (S3 bytes_sent) |
| file_size | 524288 | long | Access log: total size of the S3 object (S3 object_size) |
| vendor_total_time_ms | 145 | long | Access log: total request duration in milliseconds |
| vendor_turn_around_time_ms | 12 | long | Access log: time S3 spent processing the request in milliseconds |
| vendor_request_id | A1B2C3D4E5F60718 | string | Access log: S3 request ID |
| http_request_method | PUT | string | Access log: HTTP method parsed from the request line |
| http_request_path | /inbox/2026/04/15/upload.png | string | Access log: HTTP request path parsed from the request line |
| http_version | 1.1 | keyword | Access log: HTTP version parsed from the request line (bare version, e.g. 1.1) |
| vendor_request_line | PUT /inbox/2026/04/15/upload.png HTTP/1.1 | string | Access log: raw HTTP request line (method + path + protocol), retained for forensic completeness |
| vendor_authentication_type | AuthHeader | string | Access log: S3 auth method (AuthHeader, QueryString, -) |
| vendor_signature_version | SigV4 | string | Access log: AWS signature version |
| vendor_cipher_suite | ECDHE-RSA-AES128-GCM-SHA256 | string | Access log: TLS cipher suite |
| vendor_tls_version | TLSv1.3 | string | Access log: TLS protocol version |
| vendor_host_id | abcdef0123456789 | string | Access log: S3 host_id |
| destination_hostname | example-app-uploads.s3.us-east-1.amazonaws.com | string | Access log: HTTP Host header (regional S3 endpoint FQDN). Includes region, unlike the regionless host_hostname synthesized for host_reference. |
| http_user_agent | aws-cli/2.13.0 | string | User-Agent header from the requester (CloudTrail user_agent / access log user_agent) |
| event_severity | informational | string | Informational baseline event severity set by the processing rules (routine S3 events are not alerts) |
| event_severity_level | 1 | integer | Numeric baseline event severity (1=informational); mutual pair of event_severity |
| alert_severity_level | 4 | integer | Set only by the detection rule on a cross-bucket CopyObject (4=high) |
| alert_severity | high | string | Derived by core from alert_severity_level on detection events |
| alert_category | Data Exfiltration | string | Set by the detection rule on cross-bucket CopyObject events |
| alert_signature | AWS S3 Cross-Bucket Object Copy | string | Set by the detection rule |
| alert_signature_id | aws_s3_cross_bucket_copy | string | Set by the detection rule |
| gim_event_type_code | 200000 | string | GIM type code array; file. or audit. depending on the operation; detection adds 301001 |
