Create Pipeline Rules with Assets
A set of pipeline rules can be used to set the associated assets
field on a message, update existing assets, and retrieve asset information to further enrich messages. Asset-related pipeline functions allow you to do more with assets via processing pipelines.
set_associated_assets
This pipeline rule populates the associated_assets
and associated_asset_categories
fields on the message using GIM schema fields. The associated assets
field will be an array with the ID of each asset that matches a field on the message to an asset field of the same type. The associated_assets
field will determine which assets are displayed on the expanded log message on the search page. The associated_asset_categories
field will be an array that includes all associated asset categories.
Machine Asset Message Fields
The following fields are used to associate machine assets:
IP Address Message Fields | MAC Address Message Fields | Hostname Message Fields |
source_ip
source_ipv6
source_nat_ip
destination_ip
destination_nat_ip
host_ip
vendor_private_ip
vendor_private_ipv6
vendor_public_ip
vendor_public_ipv6
event_observer_ip
User Asset Message Fields
The following fields are used to associate user assets:
Username Message Fields | User ID Message Fields | Email Message Fields |
user_name
target_user_name
user_name_mapped
machine_asset_lookup
This pipeline rule takes a lookup_type
and value parameter. lookup_type
can be either name, ip, mac, or hostname. The value field is the value used to look up the specified type. The rule assumes that the lookup will be unique, so if multiple assets happen to match the lookup, only one will be returned. If the lookup has a match, it will return a map with the following structure:
"id": "string"
"name": "string",
"priority": number,
"category": ["string", "array"],
"details": {
"type": "machine",
"description": "string",
"owner": "string",
"ip_addresses": ["string", "array"],
"mac_addresses": ["string", "array"],
"hostnames": ["string", "array"],
"custom_fields": Map
The custom_fields
map structure will depend on the custom fields defined for a given asset. Each entry will have a string key and an array of values that are either strings, dates, or numbers.
These fields can then be used to enrich the message in a more targeted way than the set_associated_assets
rule. For example, to look up an asset by the source_ip
field and then set fields on the message based on the asset returned would look similar to:
rule "machine_asset_lookup"
has_field("source_ip")
let asset = machine_asset_lookup(lookup_type:"ip", value:to_string($message.source_ip));
let details = asset.details;
set_field("asset_id", asset.id);
set_field("asset_name", asset.name);
set_field("asset_description", details.description);
set_field("asset_ips", details.ip_addresses);
set_field("asset_macs", details.mac_addresses);
set_field("asset_hostnames", details.hostnames);
machine_asset_update
This rule will update IP addresses and hostnames of existing machine assets. The parameters are:
lookup_type
: Either name, ip, mac, or hostname. -
lookup_value
: The value for thelookup_type
ip_addresses
: String or array of IP addresses to update the asset with [optional]. -
hostnames
: String or array of hostnames to update the asset with [optional].
rule "machine_asset_update"
true
machine_asset_update(lookup_type:"mac", lookup_value:"AA:BB", ip_addresses:"10.0.0.0");
Using this rule on DHCP logs, for example, can keep existing assets up to date based on incoming logs.
true
machine_asset_update(lookup_type:"mac", lookup_value:$message.mac, ip_addresses:to_string($message.new_ip));
user_asset_lookup
This pipeline rule is used to look up a user asset and enrich log messages with user asset data. The rule takes a lookup_type
can be either name, username, user_id, or email. The value field is the value to be used in looking up the specified type. The rule assumes that the lookup will be unique, so if multiple assets happen to match the lookup, only one will be returned. If the lookup has a match, it will return a map with the following structure:
"id": "string"
"name": "string",
"priority": number,
"details": {
"type": "user",
"username": "string",
"user_ids": ["string", "array"],
"email_addresses": ["string", "array"],
"first_name": "string",
"last_name": "string"
rule. For example, looking up an asset by the username field and then set fields on the message based on the asset returned would look similar to:
rule "user_asset_lookup"
has_field(“username”)
let asset = user_asset_lookup(lookup_type:"username", value:"username");
set_field("asset_type", details.type);
set_field("asset_username", details.username);
set_field("asset_user_ids", details.user_ids);
set_field("asset_emails", details.email_addresses);
