Set a Data Retention Policy
You can set a data retention policy for your Data Lake so that data is held in storage for only the amount of time you determine is required. This ability can be a key part of compliance with legal and regulatory requirements. In fact, you can set a global retention policy for the Data Lake but also include separate retention settings for individual streams, where required.
This article explains how to establish a global retention policy as well as how to set up override policies for individual streams.
Prerequisites
  • You must be a Graylog administrator to set up and manage a Data Lake.
  • You should understand your organization's retention and compliance needs.
Set Global Retention Policy
To set a global data retention policy for the Data Lake:
  1. Navigate to the Configuration tab of the Data Lake > Setup page.
  2. Under Retention settings, set the value for Maximum number of days in the Data Lake.
    Hint: You set this value using the conventions for durations from the ISO 8601 standard.
  3. Click Update configuration.
Set Stream Override Retention Policy
Warning: If you set a retention policy on a stream, that policy overrides the global policy for that data only. The global policy applies to any stream that does not have an individual stream policy applied.
To set a data retention policy for an individual stream:
  1. Navigate to the Overview tab of the Data Lake > Setup page and locate the appropriate stream.
  2. Click Data Routing.
    Hint: You can also navigate to the Streams page, locate the stream, click Data Routing, then proceed to step 3, Destinations.
  3. In the Data Lake section, click Data Retention.
  4. In the dialog box, set the value for Maximum number of days in the Data Lake.
  5. Click Update.
Further Reading
