The Juniper SRX line of firewalls combine effective security, SD-WAN, routing, switching and WAN interfaces with next-generation firewall and advanced threat mitigation capabilities. It provides secure connectivity across distributed enterprise locations.
Requirement(s)
Juniper SRX devices running Junos OS 17.4. These should be configured to send sd-syslog formatted logs.
A Graylog Server with a valid Enterprise license that is running Graylog version 5.0.3 or later.
Graylog Server Requirement
This spotlight requires Graylog Server version 5.0.3 or higher. If an earlier version is used, fields will be improperly processed.
Not Supported
N/A
Stream Configuration
“Illuminate:Juniper Messages”
Index Set Configuration
“Juniper Logs”
Log Format Examples
<14>1 2023-08-02T06:20:55.496Z RT_FLOW - RT_FLOW_SESSION_CREATE [junos@2636.1.1.1.2.129 source-address="192.168.1.2" source-port="49158" destination-address="10.10.10.10" destination-port="80" connection-tag="0" service-name="junos-http" nat-source-address="172.16.1.2" nat-source-port="29479" nat-destination-address="10.10.10.10" nat-destination-port="80" nat-connection-tag="0" src-nat-rule-type="source rule" src-nat-rule-name="trust_Zone" dst-nat-rule-type="N/A" dst-nat-rule-name="N/A" protocol-id="6" policy-name="default-permit" source-zone-name="trust" destination-zone-name="untrust" session-id="6389" username="N/A" roles="N/A" packet-incoming-interface="ge-0/0/1.0" application="UNKNOWN" nested-application="UNKNOWN" encrypted="UNKNOWN" application-category="N/A" application-sub-category="N/A" application-risk="-1" application-characteristics="N/A" src-vrf-grp="N/A" dst-vrf-grp="N/A" tunnel-inspection="Off" tunnel-inspection-policy-set="root" source-tenant="N/A" destination-service="N/A"]
<14>1 2023-08-02T06:20:13.049Z RT_IDS - RT_SCREEN_TCP [junos@2636.1.1.1.2.40 attack-name="SYN flood!" source-address="192.168.1.1" source-port="40001" destination-address="192.168.1.2" destination-port="50010" source-zone-name="trustZone" interface-name="ge-0/0/1.0" action="drop"]
Juniper SRX Logging
Junos OS must be configured to send log messages via the sd-syslog format.
When compared to standard syslog, the sd-syslog format is an overly structured system log file format. Information regarding this format can be found at:
What is Provided
Rules to normalize and enrich Juniper SRX log messages.
Juniper SRX Log Message Processing
The Illuminate processing of Juniper SRX log messages provides the following:
Field extraction, normalization and message enrichment for Juniper SRX log messages.
GIM Categorization of the following messages:
| Juniper SRX Log Type | GIM Category | GIM Subcategory |
RT_FLOW_SESSION_CLOSE
network | network.flow |
network | network.open |
IDP_ATTACK_LOG_EVENT
APPTRACK_SESSION_CLOSE
Juniper SRX Spotlight Content Pack
Dashboard: Illuminate:Juniper SRX Overview
