The Cisco ASA (Adaptive Security Appliance) is a multipurpose firewall appliance from Cisco and is generally used for packet filtering purposes, but it supports many additional features, such as stateful filtering, application inspection, NAT, DHCP, routing, VPN, etc. This technology pack will process Cisco ASA logs, providing normalization and enrichment of common events of interest.
Firepower is an extension to ASA.
This content pack supports Cisco ASA up to version 9.x or Cisco Firepower 7.1 and higher.
Configure ASA/Firepower to send logs to Graylog (see official ASA documentation: Configure Adaptive Security Appliance (ASA) Syslog) (link for PIX 500)
Graylog raw/syslog input (ASA syslog format may be rejected by Graylog due to a non-RFC compliant format. Configure an RFC 5424 output to use a Graylog syslog input. Alternatively, send the logs to a raw Graylog input).
Graylog Server with a valid Enterprise license, running Graylog version 5.0.3 or later.
Supported Version(s)
- Up to version 9.x or Cisco Firepower 7.1 and higher.
Stream Configuration
"Illuminate:Cisco Device Messages"
Index Set Configuration
- “Cisco Devices Event Log Messages”
If this index set is already defined, then nothing will be changed. If this index set does not exist, then it will be created with retention settings of a daily rotation and 90 days of retention. These settings can be adjusted as required after installation.
Log Format Examples
ASA Logs
%ASA-6-305011: Built dynamic TCP translation from DL_172_16:192.168.10.10/1234 to L3_Internet:10.10.10.10/1234Jul 13 2021 14:13:19: %ASA-6-302014: Teardown TCP connection 8065 for inside:10.10.0.100/50511 to identity:172.10.124.136/51311 duration 0:00:00 bytes 422 TCP Reset-I
Firepower Logs
Jul 13 2021 14:13:19: %FTD-6-302014: Teardown TCP connection 8065 for inside:10.10.0.100/50511 to identity:172.10.124.136/51311 duration 0:00:00 bytes 422 TCP Reset-I
%NGIPS-1-430002: EventPriority: Low, DeviceUUID:11133c5c-a6a1-11eb-a6e7-be0b98331111, InstanceID: 2, FirstPacketSecond:2023-02-30T11:31:19Z, ConnectionID: 4, AccessControlRuleAction: Allow, SrcIP:172.10.10.10, DstIP: 172.16.20.10, ICMPType: Echo Request, ICMPCode: NoCode, Protocol: icmp, IngressInterface:inside, EgressInterface: outside, ACPolicy:Default Allow All Traffic, AccessControlRuleName: mytest, Client:ICMP client, ApplicationProtocol: ICMP,InitiatorPackets: 11, ResponderPackets: 0, InitiatorBytes: 74, ResponderBytes: 0, NAPPolicy: Tuned Security and Connectivity
%NGFW-1-430002: EventPriority: Low, DeviceUUID:11133c5c-a6a1-11eb-a6e7-be0b98331111, InstanceID: 2, FirstPacketSecond:2023-02-30T11:31:19Z, ConnectionID: 4, AccessControlRuleAction: Allow, SrcIP:172.10.10.10, DstIP: 172.16.20.10, ICMPType: Echo Request, ICMPCode: NoCode, Protocol: icmp, IngressInterface:inside, EgressInterface: outside, ACPolicy:Default Allow All Traffic, AccessControlRuleName: mytest, Client:ICMP client, ApplicationProtocol: ICMP,InitiatorPackets: 11, ResponderPackets: 0, InitiatorBytes: 74, ResponderBytes: 0, NAPPolicy: Tuned Security and Connectivity
Routing Table
Supported Cisco Event types:
| Cisco Type | event_source_product |
| %ASA | CISCO-ASA |
| %NGIPS | CISCO-ASA |
| %NGFW | CISCO-ASA |
| %FTD | CISCO-ASA |
What is Provided
Parsing rules to extract Cisco ASA logs into Graylog schema compatible fields.
An overview dashboard with 4 tabs. These tabs are ASA Overview, Network, Device Authentication, High Priority Messages.
A dashboard for IDS/IPS messages. To get these messages, Cisco ASA may require a specific license.
ASA Message Processing
The Illuminate processing of ASA Firewall log messages provides the following:
Field extraction, normalization and message enrichment for SFOS log messages.
GIM Categorization of the following messages:
Cisco Event Code GIM Event Type Code GIM Event Type 106002 129999 Network Message 106100 120000 Network Connection 106102 120000 Network Connection 106103 120000 Network Connection 106001 120000 Network Connection 106006 120000 Network Connection 106007 120000 Network Connection 106015 120000 Network Connection 106016 170001 Network Alert 106017 170001 Network Alert 106018 129999 Network Message 110002 120000 Network Connection 110003 120100 Network Routing 113008 109999 Authentication Message 113012 109999 Authentication Message 113021 100000 Logon 113006 100000 Logon 113007 100000 Logon 302013 120200 Network Connection Initiated 302014 120300 Network Connection Initiated 302015 120200 Network Connection Initiated 302016 120300 Network Connection Initiated 302018 120300 Network Connection Initiated 302022 120200 Network Connection Initiated 302023 120300 Network Connection Initiated 302024 120200 Network Connection Initiated 302025 120300 Network Connection Initiated 302026 120200 Network Connection Initiated 302027 120300 Network Connection Initiated 302036 120300 Network Connection Initiated 302303 120200 Network Connection Initiated 302304 120300 Network Connection Initiated 302306 120300 Network Connection Initiated 313004 129999 Network Message 338001 179999 Alert Message 338002 179999 Alert Message 338003 179999 Alert Message 338004 179999 Alert Message 338005 179999 Alert Message 338006 179999 Alert Message 338007 179999 Alert Message 338008 179999 Alert Message 338201 179999 Alert Message 338202 179999 Alert Message 338203 179999 Alert Message 338204 179999 Alert Message 400000 170001 Alert Message 400001 170001 Alert Message 400002 170001 Alert Message 400003 170001 Alert Message 400004 170001 Alert Message 400005 170001 Alert Message 400006 170001 Alert Message 400010 170001 Alert Message 400011 170001 Alert Message 400012 170001 Alert Message 400013 170001 Alert Message 400014 170001 Alert Message 400015 170001 Alert Message 400016 170001 Alert Message 400017 170001 Alert Message 400018 170001 Alert Message 400019 170001 Alert Message 400020 170001 Alert Message 400021 170001 Alert Message 400022 170001 Alert Message 400034 170001 Alert Message 400035 170001 Alert Message 400036 170001 Alert Message 400037 170001 Alert Message 400038 170001 Alert Message 400039 170001 Alert Message 400040 170001 Alert Message 400042 170001 Alert Message 400043 170001 Alert Message 400044 170001 Alert Message 400045 170001 Alert Message 400046 170001 Alert Message 400047 170001 Alert Message 400048 170001 Alert Message 400049 170001 Alert Message 400007 170001 Alert Message 400008 170001 Alert Message 400009 170001 Alert Message 400023 170001 Alert Message 400024 170001 Alert Message 400025 170001 Alert Message 400026 170001 Alert Message 400027 170001 Alert Message 400028 170001 Alert Message 400029 170001 Alert Message 400030 170001 Alert Message 400031 170001 Alert Message 400032 170001 Alert Message 400033 170001 Alert Message 400041 170001 Alert Message 400050 170001 Alert Message 410002 120000 Network Connection 421001 120000 Network Connection 500005 120000 Network Connection 502101 110000 Account Created 502102 110500 Account Locked 507003 120000 Network Connection 604103 299999 DHCP Default Event 605004 100000 Logon 605005 100000 Logon 606001 100000 Logon 606002 100000 Logout 606003 100000 Logon 606004 100000 Logout 611101 100500 Credential Validation 611102 100500 Credential Validation 611103 102500 Logoff 710002 120000 Network Connection 710003 120000 Network Connection 710005 120000 Network Connection 710006 129999 Network Connection 772003 100000 Logon 772004 100000 Logon 772005 100000 Logon 772006 100000 Logon 815002 120000 Network Connection
Supported Event IDs for ASA and Firepower
106001 | 106002 | 106006 | 106007 | 106010 | 106012 | 106013 | 106014 | 106016 | 106017 | 106018 | 106021 | 106023 | 106100 | 106101 | 106102 | 106103 | 109005 | 109006 | 109007 | 109008| 109024 | 109025 | 110002 | 110003 | 111007 | 111008 | 111009 | 111010 | 113003 | 113004 | 113005 | 113006 | 113007 | 113008 | 113009 | 113011 | 113012 | 113019 | 113021 | 113022 | 113023| 113029 | 113030 | 113031 | 113032 | 113033 | 113034 | 113035 | 113036 | 113038 | 113039 | 199020 | 199021 |
201002 | 201003 | 201004 | 201005 | 201006 | 201009 | 201010 | 201011 | 201012 | 201013 | 202010 | 209003 | 209004 | 209005 | 216001 |
302010 | 302013 | 302014 | 302015 | 302016 | 302018 | 302020 | 302021 | 302022 | 302023 | 302024 | 302025 | 302026 | 302027 | 302036 | 302304 | 302305 | 302306 | 303002 | 304001 | 304002| 304003 | 304004 | 304005 | 304006 | 304007 | 305005 | 305006 | 305011 | 305012 | 305019 | 305020 | 308001 | 313001 | 313004 | 313005 | 313008 | 313009 | 316001 | 318001 | 318101 | 321005| 321006 | 322002 | 322003 | 325001 | 325002 | 326013 | 331001 | 331002 |
400010 | 400014 | 400011 | 400014 | 405001 | 410001 | 401002 | 401003 | 401004 | 401005 | 405002 | 407001 | 407002 | 410002 | 414001 | 415007 | 415008 | 415009 | 415010 | 415011 | 415012| 415013 | 415014 | 418001 | 419002 | 419005 | 419006 | 420002 | 420003 | 421001 | 421002 | 421007 | 429002 | 429003 | 434002 | 434003 |
500001 | 500002 | 500004 | 500005 | 502101 | 502102 | 502103 | 502111 | 502112 | 507003 |
602303 | 602304 | 602305 | 604101 | 604102 | 604103 | 604104 | 604105 | 604201 | 604202 | 604203 | 604204 | 604205 | 604206 | 604207 | 604208 | 605005 | 606001 | 606002 | 606003 | 606004| 607001 | 608001 | 608002 | 608003 | 608004 | 608005 | 609001 | 609002 | 602101 | 611101 | 611102 | 611103 | 611301 | 611303 | 613004 | 620001 |
710002 | 710005 | 710003 | 710006 | 713041 | 713042 | 713049 | 713050 | 713120 | 713172 | 713201 | 713230 | 713231 | 713257 | 713903 | 713904 | 713905 | 716001 | 716002 | 716055 | 716056| 716057 | 716058 | 716059 | 716060 | 716500 | 716501 | 716502 | 716503 | 716504 | 716505 | 716506 | 716508 | 716509 | 716510 | 716512 | 716513 | 716515 | 716516 | 716517 | 716518 | 716519| 716520 | 716521 | 716522 | 721001 | 721002 | 721003 | 721004 | 721005 | 721006 | 721007 | 721008 | 721009 | 721010 | 721011 | 721012 | 721013 | 721014 | 721015 | 721016 | 721017 | 721018| 721019 | 722004 | 722005 | 722006 | 722007 | 722008 | 722009 | 722010 | 722011 | 722012 | 722013 | 722014 | 722021 | 722022 | 722023 | 722026 | 722027 | 722028 | 722032 | 722033 | 722034| 722037 | 722038 | 722042 | 722043 | 722044 | 722046 | 722047 | 722048 | 722049 | 722050 | 722051 | 725002 | 725001 | 725003 | 725007 | 725016 | 733100 | 737001 | 737002 | 737003 | 737004| 737005 | 737006 | 737007 | 737008 | 737009 | 737010 | 737011 | 737012 | 737013 | 737014 | 737015 | 737016 | 737017 | 737018 | 737019 | 737023 | 737024 | 737025 | 737027 | 737028 | 737029| 737030 | 737031 | 737032 | 737033 | 737034 | 737035 | 737036 | 737038 | 746014 | 746015 | 746016 | 750001 | 750002 | 750003 | 750004 | 750005 | 750006 | 750007 | 750008 | 750009 | 750010| 750014 | 750015 | 750016 | 751001 | 751002 | 751003 | 751004 | 751005 | 751006 | 751007 | 751008 | 751009 | 751010 | 751011 | 751012 | 751013 | 751014 | 751015 | 751016 | 751017 | 751019| 751020 | 751021 | 751022 | 751023 | 751024 | 751025 | 751026 | 751027 | 751028 | 752002 | 752003 | 752004 | 752005 | 752006 | 752007 | 752010 | 752012 | 752013 | 752014 | 752015 | 752016| 768001 | 768002 | 768003 | 768004 | 769001 | 769002 | 769003 | 769004 | 769005 | 769006 | 769007 | 769008 | 769009 | 772002 | 772003 | 772004 | 772005 | 772006 | 775001 | 775003 | 775004| 775005 | 779003 | 779004 | 779005 | 779006 | 779007 |
Basic Support for CTS SXP Event IDs (application_name and vendor_event_description)
776001 | 776002 | 776003 | 776004 | 776005 | 776006 | 776007 | 776008 | 776009 | 776010 | 776011 | 776012 | 776013 | 776014 | 776015 | 776016 | 776017 | 776018 | 776019 | 776020|
805001 | 805002 | 805003 | 812002|
Basic Support
338001 | 338002 | 338003 | 338004 | 338005 | 338006 | 338007 | 338008 | 338101 | 338102 | 338103 | 338104 | 338201 | 338202 | 338203 | 338204|
Additional Firepower Event IDs
430001, 430002, 430003, 430004, 430005
