This guide describes the recommended way to install Graylog on Ubuntu 20.04 LTS and 22.04. All links and packages are present at the time of writing.
Prerequisites
Graylog 5.0 requires the following to maintain compatibility with its software dependencies:
- OpenJDK 17 (This is embedded in Graylog 5.0 and does not need to be separately installed.)
- OpenSearch 1.x, 2.x or Elasticsearch 7.10.2
- MongoDB 5.x or 6.x
MongoDB
Graylog 5.0 is compatible with MongoDB 5.x-6.x.
1. Installing MongoDB on Ubuntu should follow the tutorial for Ubuntu from the MongoDB documentation:
sudo apt-get install gnupg
wget -qO - https://www.mongodb.org/static/pgp/server-6.0.asc | sudo apt-key add -
# Ubuntu 18.04
echo "deb [ arch=amd64,arm64 ] https://repo.mongodb.org/apt/ubuntu bionic/mongodb-org/6.0 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org-6.0.list
# Ubuntu 20.04
echo "deb [ arch=amd64,arm64 ] https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/6.0 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org-6.0.list
# Ubuntu 22.04
echo "deb [ arch=amd64,arm64 ] https://repo.mongodb.org/apt/ubuntu jammy/mongodb-org/6.0 multiverse" | sudo tee /etc/apt/sources.list.d/mongodb-org-6.0.list
sudo apt-get update
sudo apt-get install -y mongodb-org
2. For example, in corporate proxies and other non-free environments, you can use a keyserver approach via a widget:
wget -qO- 'http://keyserver.ubuntu.com/pks/lookup?op=get&search=0xf5679a222c647c87527c2f8cb00a0bd1e2c63c11' | sudo apt-key add -
3. Enable MongoDB during the operating system’s start up and verify it is running:
sudo systemctl daemon-reload
sudo systemctl enable mongod.service
sudo systemctl restart mongod.service
sudo systemctl --type=service --state=active | grep mongod
OpenSearch
If you are using OpenSearch as your data node, then follow the steps below to install OpenSearch 2.0.1.
The recommended method of installation is to follow the user documentation provided by the OpenSearch service. To set up the OpenSearch service with your Graylog instance, read the following recommendations and guidance.
1. You may prefer to disable transparent hugepages to improve performance before installing.
sudo su
cat > /etc/systemd/system/disable-transparent-huge-pages.service <<EOF
Description=Disable Transparent Huge Pages (THP)
DefaultDependencies=no
After=sysinit.target local-fs.target
[Service]
Type=oneshot
ExecStart=/bin/sh -c 'echo never | tee /sys/kernel/mm/transparent_hugepage/enabled > /dev/null'
[Install]
WantedBy=basic.target
EOF
sudo systemctl enable disable-transparent-huge-pages.service
sudo systemctl start disable-transparent-huge-pages.service
2. Create your OpenSearch user.
sudo adduser --system --disabled-password --disabled-login --home /var/empty --no-create-home --quiet --force-badname --group opensearch
3. Now, you can begin the installation of the OpenSearch tarball. Full instructions for tarball installation are recorded in the OpenSearch documentation.
#Download Opensearch 2.0.1
wget https://artifacts.opensearch.org/releases/bundle/opensearch/2.0.1/opensearch-2.0.1-linux-x64.tar.gz
#Create Directories
sudo mkdir -p /graylog/opensearch/data
sudo mkdir /var/log/opensearch
#Extract Contents from tar
sudo tar -zxf opensearch-2.0.1-linux-x64.tar.gz
sudo mv opensearch-2.0.1/* /graylog/opensearch/
#Set Permissions
sudo chown -R opensearch:opensearch /graylog/opensearch/
sudo chown -R opensearch:opensearch /var/log/opensearch
sudo chmod -R 2750 /graylog/opensearch/
sudo chmod -R 2750 /var/log/opensearch
#Create empty log file
sudo -u opensearch touch /var/log/opensearch/graylog.log
#Create System Service
sudo su
cat > /etc/systemd/system/opensearch.service <<EOF
[Unit]
Description=Opensearch
Documentation=https://opensearch.org/docs/latest
Requires=network.target remote-fs.target
After=network.target remote-fs.target
ConditionPathExists=/graylog/opensearch
ConditionPathExists=/graylog/opensearch/data
[Service]
Environment=OPENSEARCH_HOME=/graylog/opensearch
Environment=OPENSEARCH_PATH_CONF=/graylog/opensearch/config
ReadWritePaths=/var/log/opensearch
User=opensearch
Group=opensearch
WorkingDirectory=/graylog/opensearch
ExecStart=/graylog/opensearch/bin/opensearch
# Specifies the maximum file descriptor number that can be opened by this process
LimitNOFILE=65535
# Specifies the maximum number of processes
LimitNPROC=4096
# Specifies the maximum size of virtual memory
LimitAS=infinity
# Specifies the maximum file size
LimitFSIZE=infinity
# Disable timeout logic and wait until process is stopped
TimeoutStopSec=0
# SIGTERM signal is used to stop the Java process
KillSignal=SIGTERM
# Send the signal only to the JVM rather than its control group
KillMode=process
# Java process is never killed
SendSIGKILL=no
# When a JVM receives a SIGTERM signal it exits with code 143
SuccessExitStatus=143
# Allow a slow startup before the systemd notifier module kicks in to extend the timeout
TimeoutStartSec=180
[Install]
WantedBy=multi-user.target
EOF
Graylog Configuration for OpenSearch
1. Begin by opening the yml
file:
nano /graylog/opensearch/config/opensearch.yml
2. Update the following fields for a minimum unsecured running state:
cluster.name: graylog
node.name: ${HOSTNAME}
path.data: /graylog/opensearch/data
network.host: ${HOSTNAME}
discovery.seed_hosts: ["SERVERNAME01", "SERVERNAME02", "SERVERNAME03"]
cluster.initial_master_nodes: ["SERVERNAME01", "SERVERNAME02", "SERVERNAME03"]
3. Enable JVM options:
sudo nano /graylog/opensearch/config/jvm.options
4. Now, update the XMS settings with half of the installed system memory.
5. Configure the kernel parameters at runtime:
sudo sysctl -w vm.max_map_count=262144
sudo echo 'vm.max_map_count=262144' >> /etc/sysctl.conf
6. Finally, enable the system service:
sudo systemctl enable opensearch.service
sudo systemctl start opensearch.service
Elasticsearch
Elasticsearch 7.10.2 is the only version that is compatible with Graylog 5.0; however, we recommend OpenSearch for new Graylog cluster installations.
1. The following commands will begin the installation of the open-source version of Elasticsearch. See the Elasticsearch install page for more detailed instructions.
wget -q https://artifacts.elastic.co/GPG-KEY-elasticsearch -O myKey
sudo apt-key add myKey
echo "deb https://artifacts.elastic.co/packages/oss-7.10.2/apt stable main" | sudo tee -a /etc/apt/sources.list.d/elastic-7.10.2.list
sudo apt-get update && sudo apt-get install elasticsearch-oss
2. Modify the Elasticsearch configuration file (/etc/elasticsearch/elasticsearch.ym
l), set the cluster name to Graylog
, and uncomment action.auto_create_index: false
to enable the action:
sudo tee -a /etc/elasticsearch/elasticsearch.yml > /dev/null <<EOT
EOT
3. After you have modified the configuration, you can start Elasticsearch and verify it is running:
sudo systemctl enable elasticsearch.service
sudo systemctl restart elasticsearch.service
sudo systemctl --type=service --state=active | grep elasticsearch
Graylog
Install the Graylog Open repository configuration and Graylog itself with the following commands:
wget https://packages.graylog2.org/repo/packages/graylog-5.0-repository_latest.deb
sudo dpkg -i graylog-5.0-repository_latest.deb
sudo apt-get update && sudo apt-get install graylog-server
If you are installing Graylog Operations, then you will use the following commands:
sudo apt-get install graylog-enterprise
Edit the Configuration File
Read the instructions within the configurations file and edit as needed, located at /etc/graylog/server/server.conf
. Additionally add password_secret
and root_password_sha2
as these are mandatory and Graylog will not start without them.
1. To create your root_password_sha2
, run the following command:
echo -n "Enter Password: " && head -1 </dev/stdin | tr -d '\n' | sha256sum | cut -d" " -f1
2. To generate a password_secret
pwgen -N 1 -s 96
To be able to connect to Graylog, set http_bind_address
to the public host name or a public IP address of the machine with which you can connect. More information about these settings can be found in Configuring the Web Interface.
3. Enable Graylog during the operating system’s start up:
sudo systemctl enable graylog-server.service
sudo systemctl start graylog-server.service
sudo systemctl --type=service --state=active | grep graylog
4. The last step is to ingest messages into your Graylog and extract the messages with extractors or use pipelines to work with the messages.
Multiple Server Setup
If you plan to have multiple servers taking care of different roles in your cluster as we have in this big production setup, you need to modify only a few settings. This is covered in our Multi-Node Setup guide. The Default File Location guide will give you the file you need to modify in your setup.
