Configurations must be set for Graylog to start after installation. Both the Graylog and Elasticsearch server.conf elasticsearch.yml configuration files contain the key details needed for initial configuration.
This guide will provide you with the essential settings to get Graylog up and running. There are many other important settings in these files, and we encourage you to review them once you are up and running. For more details, please see server.conf.
server.conf
The file is the Graylog configuration file. The default location for server.conf is: server.conf /etc/graylog/server/server.conf.
- Typically, entries are a single line:
propertyName=propertyValuepropertyName:propertyValue
- White space that appears between the property name and property value is ignored, so the following are equivalent:
name=Stephenname = Stephen
- White space at the beginning of the line is also ignored.
- Lines that start with the comment characters
or!are ignored. Blank lines are also ignored.# - The property value is generally terminated by the end of the line.
- White space following the property value is not ignored and is treated as part of the property value.
- The character's newline, carriage return, and tab can be inserted with characters
\n,\r, and\t, respectively.
General Properties
is_master = true- If running more than one instance of the Graylog server, you MUST designate (only) one
node as the leader. This node will perform periodical and maintenance actions that follower nodes won’t.graylog-server
password_secret = <secret>- You MUST set a secret that is used for password encryption and salting. The server refuses to start if this value is not set. Use at least 64 characters. If you run multiple
nodes, make sure you use the samegraylog-serverfor all of them.password_secret
pwgen -N 1 -s 96.root_username = admin- The default root user is named admin.
root_password_sha2 = <SHA2>- A SHA2 hash of the password you will use for your initial login. Insert a SHA2 hash generated with
and you will be able to log into the web interface with username admin and password yourpassword.echo -n "Enter Password: " && head -1 </dev/stdin | tr -d '\n' | sha256sum | cut -d" " -f1
Web Properties
http_bind_address = 127.0.0.1:9000- The network interface used by the Graylog HTTP interface.
- This address and port is used by default in the
http_publish_uri.
http_publish_uri = https://127.0.0.1:9000/- Web interface listen URI.
- The HTTP URI of this Graylog node, which is used by all clients using the Graylog web interface.
Elasticsearch Properties
elasticsearch_hosts = https://node1:9200,https://user:password@node2:19200- List of Elasticsearch hosts Graylog should connect to.
- Need to be specified as a comma-separated list of valid URIs for the HTTP ports of Elasticsearch nodes.
- If one or more Elasticsearch hosts require authentication, include the credentials in each node URI that requires authentication.
- Default:
https://127.0.0.1:9200You may retain the default setting only if Elasticsearch is installed on the same host as the Graylog server.
MongoDB
mongodb_uri = mongdb://...- MongoDB connection string. Enter your MongoDB connection and authentication information here.
- See https://docs.mongodb.com/manual/reference/connection-string/ for details.
- Examples:
- Simple:
mongodb_uri = mongodb://localhost/graylog - Authenticate against the MongoDB server:
mongodb_uri = mongodb://grayloguser:secret@localhost:27017/graylog - Use a replica set instead of a single host:
mongodb_uri=mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog?replicaSet=rs01
- Simple:
Outgoing HTTP
http_proxy_uri =- HTTP proxy for outgoing HTTP connections.
http_non_proxy_hosts =- A list of hosts that should be reached directly, bypassing the configured proxy server.
- This is a list of patterns separated by ”,”. The patterns may start or end with a “*” for wildcards.
- Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
elasticsearch.yml
is the Elasticsearch configuration file. The default location for Elasticsearch.yml is: Elasticsearch.yml /etc/elasticsearch/elasticsearch.yml.
Several values must be properly configured for Elasticsearch to work properly.
cluster.name: graylog- This value may be set to anything the customer wishes, though we recommend using “graylog”.
- This value must be the same for every Elasticsearch node in a cluster.
network.host: 172.30.4.105- By default, Elasticsearch only binds to loop-back addresses (e.g., 127.0.0.1). This is sufficient to run a single development node on a server.
- To communicate and form a cluster with nodes on other servers, the node will need to bind to a non-loopback address.
http.port: 9200- Port Elasticsearch will listen on. We recommend the default value.
discovery.zen.ping.unicast.hosts: ["es01.acme.org", "es02.acme.org"]- Elasticsearch uses a custom discovery implementation called “Zen Discovery” for node-to-node clustering and leader election. To form a cluster with nodes on other servers, provide a seed list of other nodes in the cluster that are likely to be live and contactable.
- May be specified as an IP address or FQDN.
