Docker is a set of platform-as-a-service products that use OS-level virtualization to deliver software in packages called containers. This product allows you to run and configure Graylog in concert with its dependencies: MongoDB and Elasticsearch or OpenSearch.
You will need a recent version of Docker, at least v20.10.10. In addition, use the following Docker images in this chapter:
If you prefer to run the containers together, you could configure all the containers above in a yaml file. To do this install Docker Compose. Refer to Settings for compose examples.
Warning: All configuration examples are created to run on a local computer. Should those be used on external servers, adjust GRAYLOG_HTTP_EXTERNAL_URI and add GRAYLOG_HTTP_PUBLISH_URI and GRAYLOG_HTTP_EXTERNAL_URI according to the Server.Conf documentation.
How to Get in Log Data
You can create different kinds of inputs under System / Inputs. However, you can only use ports that have been properly mapped to your Docker container; otherwise, data will not show up in the Graylog UI.
Copy
docker run --link mongo --link elasticsearch \
   -p 9000:9000 -p 12201:12201 -p 1514:1514 -p 5555:5555 \
   -e GRAYLOG_HTTP_EXTERNAL_URI="http://127.0.0.1:9000/" \
   -d graylog/graylog:5.0
For example, to start a Graylog Docker container listening on port 5555, stop your container and recreate it, while appending -p 5555:5555 to your docker run command:
Similarly, the same can be done for UDP by appending -p 5555:5555/udp.
After ensuring that your Graylog Docker container is listening on :5555, create a Raw/Plaintext Input by navigating to your Graylog port, e.g. https://localhost:9000/system/inputs.
Once on the Inputs page, search for Raw/Plaintext TCP and click Launch new input.
After launching the input, you’ll see a dialog box pop up with several options. You can leave most these options as their defaults, but note that you’ll need to provide a name for the input, as well as select the node, or “Global” for the location for the input.
After that you can send a plain text message to the Graylog Raw/Plaintext TCP input running on port 5555 using the following command:
Copy
echo 'First log message' | nc localhost 5555
You can then view the message in the Graylog UI:
Settings
Graylog comes with a default configuration that works out of the box, but you have to set a password for the admin user and the web interface needs to know how to connect from your browser to the Graylog REST API.
Both settings can be configured via environment variables (also see Configuration):
Copy
-e GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
In this case you can log into Graylog with the username and password admin.
Generate your own admin password with the following command and put the SHA-256 hash into the GRAYLOG_ROOT_PASSWORD_SHA2 environment variable:
Copy
echo -n "Enter Password: " && head -1 < /dev/stdin | tr -d '\n' | sha256sum | cut -d " " -f1
All these settings and command line parameters can be put in a docker-compose.yml file, so that they don’t have to be executed one after the other.
Warning: The following example does not persist any data and configurations. You should read the section Persisting Data to add persistence to your docker-compose file.
Example Version 3
Copy
  version: '3'
  services:
    mongo:
      image: mongo:5.0.13
      networks:
        - graylog
# Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/7.10/docker.html
    elasticsearch:
      image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2
      environment:
        - http.host=0.0.0.0
        - transport.host=localhost
        - network.host=0.0.0.0
        - "ES_JAVA_OPTS=-Dlog4j2.formatMsgNoLookups=true -Xms512m -Xmx512m"
      ulimits:
      memlock:
      soft: -1
      hard: -1
      deploy:
      resources:
      limits:
      memory: 1g
      networks:
        - graylog
    graylog:
      image: graylog/graylog:5.0
      environment:
    - GRAYLOG_PASSWORD_SECRET=somepasswordpepper
# Password: admin
    - GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
    - GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9000/
      entrypoint: /usr/bin/tini -- wait-for-it elasticsearch:9200 --  /docker-entrypoint.sh
      networks:
        - graylog
      restart: always
      depends_on:
        - mongo
        - elasticsearch
      ports:
    - 9000:9000
# Syslog TCP
    - 1514:1514
# Syslog UDP
    - 1514:1514/udp
# GELF TCP
    - 12201:12201
# GELF UDP
    - 12201:12201/udp
      networks:
      graylog:
      driver: bridge
After starting all three Docker containers by running docker-compose up, you can open the URL https://127.0.0.1:9000 in a web browser and log in with username admin and password admin (make sure to change the password later). Change GRAYLOG_HTTP_EXTERNAL_URI= to your server IP if you run Docker remotely.
Configuration
Every configuration option can be set via environment variables. Simply prefix the parameter name with GRAYLOG_ and put it all in upper case.
For example, setting up the SMTP configuration for sending Graylog alert notifications via email, the docker-compose.yml would look like this:
Copy
version: '2'
services:
mongo:
image: "mongo:5.0.13"
# Other settings [...]
elasticsearch:
graylog:
environment:
GRAYLOG_TRANSPORT_EMAIL_ENABLED: "true"
GRAYLOG_TRANSPORT_EMAIL_HOSTNAME: smtp
GRAYLOG_TRANSPORT_EMAIL_PORT: 25
GRAYLOG_TRANSPORT_EMAIL_USE_AUTH: "false"
GRAYLOG_TRANSPORT_EMAIL_USE_TLS: "false"
GRAYLOG_TRANSPORT_EMAIL_USE_SSL: "false"
Another option would be to store the configuration file outside of the container and edit it directly.
Custom Configuration Files
Instead of using a long list of environment variables to configure Graylog (see Configuration Settings), you can also overwrite the bundled Graylog configuration files.
The bundled configuration files are stored in /usr/share/graylog/data/config/ inside the Docker container.
Create the new configuration directory next to the docker-compose.ymlfile and copy the default files from GitHub:
Copy
mkdir -p ./graylog/config
cd ./graylog/config
wget https://raw.githubusercontent.com/Graylog2/graylog-docker/5.0/config/graylog.conf
wget https://raw.githubusercontent.com/Graylog2/graylog-docker/5.0/config/log4j2.xml
The newly created directory ./graylog/config/with the custom configuration files now has to be mounted into the Graylog Docker container.
This can be done by adding an entry to the volumes section of the docker-compose.yml file:
Copy
version: '2'
services:
mongodb:
image: mongo:5.0.13
elasticsearch:
image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.0
graylog:
volumes:
# Mount local configuration directory into Docker container
- ./graylog/config:/usr/share/graylog/data/config
Warning: Graylog is running as USER graylog with the ID 1100 in Docker. That ID needs to be able to read the configuration files you place into the container.
Reading Individual Configuration Settings from Files
The Graylog Docker image supports reading individual configuration settings from a file. This can be used to secure configuration settings with Docker secrets or similar mechanisms.
This has the advantage, that configuration settings containing sensitive information don’t have to be added to a custom configuration file or into an environment variable in plaintext.
The Graylog Docker image checks for the existence of environment variables with the naming scheme GRAYLOG_<CONFIG_NAME>__FILE on startup and expects the environment variable to contain the absolute path to a readable file.
For example, if the environment variable GRAYLOG_ROOT_PASSWORD_SHA2__FILE contained the value /run/secrets/root_password_hash, the Graylog Docker image would use the contents of /run/secrets/root_password_hash as value for the root_password_sha2 configuration setting.
Docker Secrets
Hint: Docker secrets are only available in Docker Swarm services starting with Docker 1.13. Please refer to Manage Sensitive Data with Docker Secrets for more details.
Example for using Docker secrets in a Docker Swarm service:
Copy
# Create SHA-256 hash of our password
echo -n 'password' | sha256sum | awk '{ print $1 }' 5e884898da28047151d0e56f8dc6292773603d0d6aabbdd62a11ef721d1542d8
# Create a Docker secret named "root_password_hash"
printf '5e884898da28047151d0e56f8dc6292773603d0d6aabbdd62a11ef721d1542d8' | \
docker secret create root_password_hash -
nlujwooo5uu6z0m91bmve79uo
docker secret ls
ID                          NAME                 DRIVER              CREATED             UPDATED
nlujwooo5uu6z0m91bmve79uo   root_password_hash                       34 seconds ago      34 seconds ago
# Create Docker Swarm service named "graylog" with access
# to the secret named "root_password_hash"
docker service create --name graylog \
--secret root_password_hash \
-e GRAYLOG_ROOT_PASSWORD_SHA2__FILE=/run/secrets/root_password_hash \
-p 9000:9000 graylog/graylog:5.0
mclk5gm39ingk51s869dc0htz
overall progress: 1 out of 1 tasks
1/1: running   [==================================================>]
verify: Service converged
docker service ls
ID                  NAME                MODE                REPLICAS            IMAGE               PORTS
mclk5gm39ing        graylog             replicated          1/1                 graylog:5.0      *:9000->9000/tcp
Persisting Data
In order to make the recorded data persistent, you can use external volumes to store all data. In the case of a container restart, this will simply re-use the existing data from the former instances.
Using Docker volumes for the data of MongoDB, Elasticsearch, and Graylog, the docker-compose.yml file looks as follows:
Copy
version: '2'
services:
mongodb:
image: mongo:5.0.13
volumes:
- mongo_data:/data/db
elasticsearch:
volumes:
environment:
- http.host=0.0.0.0
ulimits:
memlock:
soft: -1
hard: -1
mem_limit: 1g
graylog:
volumes:
- graylog_data:/usr/share/graylog/data
environment:
# Password: admin
links:
- mongodb:mongo
- elasticsearch
restart: always
depends_on:
- mongodb
- elasticsearch
ports:
- 9000:9000
# Syslog TCP
- 1514:1514
# Syslog UDP
- 1514:1514/udp
# GELF TCP
- 12201:12201
# GELF UDP
- 12201:12201/udp
# Volumes for persisting data, see https://docs.docker.com/engine/admin/volumes/volumes/
volumes:
mongo_data:
driver: local
es_data:
driver: local
graylog_data:
driver: local
Start all services with exposed data directories:
Copy
docker-compose up
Kubernetes Automatic Master Selection
Running Graylog in Kubernetes opens the challenge to set the is_master=true setting only for one node in the cluster. The problem can be solved by calculating the name of the pod if Graylog is running in a stateful set with the following environment variable:
Copy
env:
- name: POD_NAME
valueFrom:
fieldRef:
fieldPath: metadata.name
For a stateful set, the name of the first pod in a cluster always ends with -0. See the documentation about stateful sets. The master selection mechanism in docker-entrypoint.sh file does the following:
  • Examines if Graylog is running inside Kubernetes
  • Verifies that the pod name ends in -0
  • Sets is_master=true for this container
Nomad Automatic Master Selection
When running Graylog in a Nomad cluster, you must ensure that only one node in the cluster has the setting is_master=true in the server.conf file.
Whether the container is running on Nomad may be identified with an environmental check on NOMAD_ALLOC_INDEX. Should that variable be set to 0, the container will set Graylog to is_master=true. If the variable is set to anything other than 0, it will set Graylog to is_master=false.
Troubleshooting
In case you see warnings regarding open file limit, try to set the ulimit from the outside of the container:
Copy
docker run --ulimit nofile=64000:64000 ...
The devicemapper storage driver can produce problems with Graylog's disk journal on some systems. In this case please pick another driver like aufs or overlay.
Testing a Beta Version
Warning: We only recommend running pre-release versions only if you are an experienced Graylog user and are confident in the process.
You can also run a pre-release (alpha, beta, or release candidate) version of Graylog using Docker.
The pre-releases are tagged in the graylog/graylog Docker image.
See the available tags for the Graylog image on Docker Hub and pick an alpha/beta/rc tag like this:
Copy
docker run --link mongo --link elasticsearch -p 9000:9000 -p 12201:12201 -p 1514:1514 \
-e GRAYLOG_HTTP_BIND_ADDRESS="127.0.0.1:9000" \
